jdp6000
I had a clunk from forward to reverse. I replaced all the U joints and it still clunked. I just had it in for bushings and asked the mechanic to check the cause of this clunk. He fixed it. I'm not sure where this piece of rubber he replaced is but if I can ask. from what I recall he said there is was suppose to be a piece of rubber on the mount that supports the rear of the transmission (near the rearend) that was missing. Once was installed and the clunk went away. Easy way to check is to get the car up on a hoist. have someone put it in reverse and drive....the strain causes the transmission to rise and clunk on the frame when in fact it should be hitting a rubber bushing.
Jim
Jim
