Whiplash
Getting closer to dropping the body on. Just installed a new ProForm mini/high torque starter on the crate motor. The instructions were really weak and the online instructions match what came in the box.
The selenoid had only 2 places to attach wires. One large terminal for the battery and one small tab for a spade connector (included in the box) to attach to the wiring harness for the smaller starter wire. I'm assuming this is for the switch/ingition key wire.
The original larger starter has the battery terminal and an S & R connector for the to smaller harness wires. On my wiring diagram these two connectors are for the switch and the coil.
Now to add insult to injury. I'm installing and HEI Tach Drive distributor. I had the wiring harness guys put in and HEI plug in the harness to make it a clean installation. The HEI eliminates the stand alone coil.
Here's the question... How do I wire the mini starter for this setup? Options I'm thinking about include the following:
1) Just connect battery and larger red wire (I know the ground goes to the starter mounting bolt to the block) to the larger terminal, put the spade connector on the purple wire (switch wire) and connect to the tab on the starter, and ignore/eliminate the yellow wire for the coil. (I have to check if it's part of the harness or if it was a wired direct from the old coil.
2) Same as 1 above but I need to provide some kind of connection from the starter to the HEI. I'm not sure where this would need to connect to if anywhere at all.
3) I've got it all wrong and one of you will chime in with a completely different solution.
Thanks in advance.
Whiplash
Thanks in advance.
Whiplash
