The 327/365 motor in my '65 has always run nice and consistent regard engine temp while driving. Never seemed to matter whther it was a long cruise down the highway at 75mph or sitting in stop and go traffic. The temp always stayed rock steadyat 180 and some rare times only on the very hottest days stuck in traffic it would sometimes creep up to about 200 (half way between the 180 mark and the next slash mark which is unmarked).
Last summer I had to replace the temp sending unit and hearing that the replacement are usually off I was concerned but it seemed to be giving me about the same readings - maybe about 10* higher but not more than that.
When it was in the mechanics shop last week he checked the guage and sending unit by comparing to an IR gun and said it was pretty much dead on accurate. He also checked the coolant by checking the PH levels (?) and said it was perfect with a PH reading of 10.
The problem is that the last two days I've had the car out it's definately running a LOT hotter than it was. While cruising down the road it's running steady at about 200-215* but as soon as I hit stop and go traffic or sitting at a light I can watch the gauge just creep up and up to almost pegging it at 240. Once I get a clear road and can run it for a few miles it will start to lower back to about 200* again but as soon as I have to sit at a light or stuck in traffic it starts to move up to almost 240* fairly quickly (within a few minutes).
So far it hasn't overheated and it's not puking coolant when I pull into the garage and park it so any ideas on why this seems to have suddenly started? Do I need a new thermostat?
As always, thanks in advance for all your help.
