jswope
I had performance problems on my 74. Guy that installed the Edelbrock performer before I bought it, did not put a filter on it. To save a step I replaced the carb with the same model (new) and installed the recommended inline edelbrock filter (aluminum case with long paper filter). Solved problems for a short time then started running rough at low idle. Tired various things and finally revisited the filter and found it had exploded inside the holder sending pieces of filter and trash into my brand new carb.ad (less than 500 miles). I am guessing that I need to clean the carb or have it cleaned. Is this worth trying to do myself or should I take it to a pro? Is it possible that I can just open it up and clean the debris out and give it a try back on the car? If I do open it up, is there some area to look at first or should I assume the whole thing needs cleaning and dive in head first?
