6
63white
I have a problem where gas vaporizes in the secondary after the engine is off (hot). It then condenses on the secondary butterfly and runs out the butterfly arm. The result is gas leaking out the arm and onto the manifold. It is only about 10 drops but makes for an ugly situation. I've tried gaskets in an attempt to separate the carb from the maniford heat but to no avail. Any suggestions?? thanx. .....Mike
