84Turbo
What is "VE"? Before I pipe in here, I want to know so I don't misspeak.
Volumetric Efficiency.
While I'm not educated enough to quote you specific laws within physics, I don't need to be. The end results are already out in en masse in the form of dyno results. Just the same, I don't have to have 100% knowledge of how a dyno calculates it's answers, but knowing that I can give it a repeatable 'input' and it gives back a repeatable 'output' within an acceptable percentage of error is enough to justify my statements.What law of gas physics or combustion efficiency backs up your last statement?
In the end, if we had to go out and find results of testing your hypothesis, we'd find more more results supporting my statement than yours. Sorry, I'm an engineer. I need facts and figures, not just an opinion on what we'd find.
My car is a case in point. I had 1,5/8" primary headers (Hooker Competition) on my engine. I had the car dynoed. I then went to 1,3/4" primary headers (Hooker SuperComp). That was the only change made. I then had the car dynoed again. It showed a loss of low RPM torque and a slight bump in high RPM horsepower. And I'm not the only one to receive these same results with similar testing. Point proven, no?
One can find further evidence supporting the scavenging of gasses, balanced exhaust pulses, and such by reading studies done on the addition of an X- or H-pipe.
Dyno results are your "facts and figures", not "opinions".84Tubro said:Sorry, I'm an engineer. I need facts and figures, not just an opinion on what we'd find
OK, then please give your definition of backpressure? What constitutes backpressure? Where does it originate and where are it's effective bounds within the system?That's all fine, but it's immaterial. Nobody is talking about header primary pipe size, H-pipe, etc. We're talking about the the original claim that you need backpressure (caused by the pipes and mufflers)
Ok, so as you can see, backpressure is actually defined as the resistance to flow. So how can backpressure help power production at any RPM? IT CAN'T. I think the reason people began to think that pressure was in important thing to have at low RPM is because of the term delta pressure. Delta pressure is what you need to produce good power at any RPM, which means that you need to have a pressure DROP when measuring pressures from the cylinder to the exhaust tract (the term "pressure" is what I think continually confuses things). The larger the delta P measurement is, the higher this pressure drop becomes. And as earlier stated, you can understand that this pressure drop means the exhaust gas velocity is increasing as it travels from the cylinder to the exhaust system. Put simply, the higher the delta P value, the faster the exhaust gasses end up traveling. So what does all this mean? It means that it's important to have gas velocity reach a certain point in order to have good power production at any RPM (traditional engine techs sited 240 ft/sec as the magic number, but this is likely outdated by now).
The effect of having larger exhaust pipe diameters (in the primary, secondary, collector and cat-back exhaust tubes) has a direct effect on gas velocity and therefore delta P (as well as backpressure levels). The larger the exhaust diameter, the slower the exhaust gasses end up going for a given amount of airflow. Now the ***** of all this tech is that one exhaust size will not work over a large RPM range, so we are left with trying to find the best compromise in sizing for good low RPM velocity without hindering higher RPM flow ability. It doesn't take a rocket scientist to understand that an engine flows a whole lot more air at 6000 RPM than at 1000 RPM, and so it also makes sense that one single pipe diameter isn't going to acheive optiaml gas velocity and pressure at both these RPM points, given the need to flow such varying volumes.
These concepts are why larger exhaust piping works well for high RPM power but hurts low RPM power; becuase is hurts gas velocity and therefore delta P at low RPM. At higher RPM however, the larger piping lets the engine breath well without having the exhuast gasses get bundled up in the system, which would produce high levels of backpressure and therefore hurt flow. Remember, managing airflow in engines is mainly about three things; maintaining laminar flow and good charge velocity, and doing both of those with varying volumes of air. Ok, so now that all this has been explained, let's cover one last concept (sorry this is getting so long, but it takes time to explain things in straight text!).
Dyno results are your "facts and figures", not "opinions". You didn't show any dyno results. You only offered up "if we had to go out and find results", which you didn't do. I merely stated that I need more than just what your opinion of the results would be.
Ahhh- here is the article-
http://www.wheelsjamaicahost.com/wheels_forum/index.php?topic=846.0;wap2
Just my $.02
A good article. Thank you for searching and retrieving it.
The first few sentences pretty much sum up my basic thought on the "Low end torque requires exhaust backpressure" premise.
The way I've been taught is: Torque (at any RPM) is dependent upon cylinder (combustion) pressure. Reduced exhaust backpresure allows better scavenging (purging) of the burnt gasses. A reduction in the amount of residual exhaust gas left in the cylinder allows two things. 1) An increase in VE of fresh air/fuel which will create higher cylinder pressure, and 2) an increase in combustion temperature (due to less inert exhaust gas in the cylinder) which will push the cylinder pressure a bit higher, increasing torque.
Here is how back pressure can increase power at lower RPMs (as I read about it). On the exhaust stroke, the exhaust valve opens and the cylinder piston rises. Depending on the duration, there is a chance that the valve piston will reach TDC and start to move down (the intake stroke) BEFORE the exhaust valve closes completely. If there is back pressure in the exhaust manifold, then additional oxygen depleted air is forced BACK into the cylinder. The air is dirty, but there is still more air than there would be if there was no pressure. This added air increases compression Compression is negative work. The expansion is where the power is produced. , improving VE VE only makes sense, power wise, if it is combustible fuel and air that is in the cylinder. Counting inert molecules that do not produce power in the cylinder does not make sense. , and producing more power at lower RPMs. I do not see how the laws of chemistry or thermodynamics can support that theory.
Ultimately, an engine is an air pump. The more air that gets in and out, the more power it will produce. Playing with cam lift, duration, overlap, headers, combustion ratio, etc will determine how high it peaks and at what RPM.
You are absolutely correct that an engine is an air pump. However, it is a matter of how much clean, combustion supporting air that gets in the engine that determines its power, not just the amount of burned/dirty/diluted air.
I agree, but exhaust gas still contains some clean, combustion supporting air. That is the premise behind EGR. You are incorrect. Exhaust Gas Recirculation was introduced because they realized there was unburned fuel escaping into the atmosphere. Solution: mix exhaust in with the intake charge. No, No, No. EGR was introduced to reduce the pollutant NOx. By introducing an inert, non combustion supporting gas into the cylinder, the combustion temps were dropped (by the action of the inert gas molecules acting as extra mass heat sinks) below the level that it takes for the chemical reactions that will combine oxygen and nitrogen into NOx. Period.
I know what you're going to say, EGR reduced engine power. I won't argue that. BUT it reduced engine power because it uses exhaust gas IN PLACE of clean air. It mixes EG in with the clean air in the manifold BEFORE the intake stroke. So now you had clean and dirty air entering from intake runner. This reduces the amount of clean combustion supporting air. Yes. This is the same bad effect as a restrictive exhaust with excessive backpressure. Think about it.
In the back pressure situation, you still get 100% clean air on the intake stroke, combined with a small increase in compression due to air being forced back in through the exhaust valve. This small push of dirty air increases the volume of air WITHOUT reducing the amount of clean, combustion supporting air.
No, No, No, again. The cylinder volume is a set amount. You cannot have more of one thing without having to have less of another.
No, No, No. You can't be serious here.
So the back pressure forcing air back into the combustion chamber WOULD improve VE without making any change to the size of the cylinder volume. Nonsense. Pure nonsense. I've tried to explain the airflow and chemistry of what's going on in the cylinder, and you are either not understanding the principles, or are choosing to believe folklore nonsense. Residual (or forced) exhaust gas is essentially a negative component of VE. There is absolutely no performance value to allowing a bunch of exhaust to remain, or be forced into, the cylinder. (In fact, it reduces performance. Exhaust gas remaining in the cylinder reduces the vacuum level in the cylinder, reducing the pressure differential between the intake manifold and the cylinder, and thereby reducing the amount of fresh air that will pass from the intake manifold into the cylinder. Less fresh air and fuel equals less torque and horsepower.) I'm not losing any sleep with the fact that you choose to not believe the physics I've explained, but I am using up time that I could use more productively elsewhere. I recommend that you do some serious reading about how an engine works, and the chemistry of combustion. Perhaps then you will understand what I've been saying.
But naturally aspirated motors do not make 100% VE on the intake system, therefore some back pressure can increase VE.
Just to be sure we have focus on what the original statement and counterpoint was... I believe what krscholz was getting at is that having a less restrictive exhaust, such as that of larger primary headers will decrease low RPM torque. Is this still where there is a disagreement? (Short of having 1" diameter exhaust tips, the difference between a 2" and 3" rear exit would likely be negligible at low RPM.)That's fiction. Improving the engine's VE improves torque and horsepower. It does not impair it.Keep in mind, the trade-off with freer exhaust and less back pressure will be less torque at the lower end.
JohnZ, do you agree or not? It looks like by the first sentance in your last paragraph, the answer would be that you do agree. Correct?
Again, pure nonsense. You don't understand an engine's airflow or the chemistry of combustion. It doesn't matter how fancy the intake system is, if the exhaust system cannot match that flow out of the cylinder, performance will be mediocre. Please, do some reading.
I love that you're argument comes down to: "You're wrong. I'm right. Go read something that proves it!" No, I'm trying to get you to improve your mind by opening a book. It's helped countless people throughout history. Please give it a try.
But what if the exhaust system can flow MORE air than the intake system? Perhaps the intake system is one of the reasons the engine is operating at 85% volumetric efficiency? In this situation, it is possible for the "back-pressure" to force additional air into the combustion chamber and increase VE. Even if it brings VE to 86%, then it has made an improvement in power. You'll need a computer to calculate the difference, but it will be a difference. I cannot believe this. A basic fundamental fact is an engine makes power by airflow going one direction (carb to cylinder to muffler), and one direction only. Anytime the flow goes the other direction (that would be inert, oxygen-deficient post-combustion gasses), even temporarily, the engine is going to be experiencing a reduction in torque and horsepower. I didn't write the rules. That's just the way they happen to work.
Paul, we'd be talking about a normally aspirated, carburated, 1975 V8 with no emissions. I was unable to determine if krschoulz had kept the OEM exhaust manifolds and just did a 'cat back' or if he did the whole shebang.Wait a minute.
After monitoring this, what exactly are we talking about?
Which engine?
Forced induction or not?
EGR or not?
Computer command control or not??
Fuel injected or not?
...<snip>...
