I was wrong.
84Turbo was right.
Most websites simply advertise that their smaller primary headers increase low RPM torque, but don't explain why. It is usually "explained" as back pressure. That is not true, and I fell for it.
I finally found some information that explained why smaller diameter exhaust primaries CAN (but not definitely) increase low end torque.
I'll summarize because the actual explanation was rather long:
Exhaust gas leaving the combustion chamber has 3 distinct phases
1) The high pressure head. This is just as the burned gas leaves the combustion chamber and is caused by the piston traveling up. The air being forced out of the chamber is of a higher pressure than the air in the manifold.
2) The medium pressure body. As the pressure in the combustion chamber and the pressure in the exhaust manifold equalize.
3) The low pressure tail. The manifold and header now have the same amount of pressure, but the exhaust gas is still moving away from the chamber. This creates a low pressure vacuum near the exhaust valve.
If timed correctly with overlap in the cam, it is possible for the low pressure tail of one cylinder to coincide with the overlap (period where both exhaust and intake valves are open before the induction stroke) of another cylinder. This will suck air into the combustion chamber through the open intake valve BEFORE the piston begins the intake stroke. Means more clean air enters the combustion chamber = improved VE = more power.
This effect is referred to as exhaust scavenging. This is the goal of tuned headers and X or H pipes.
If the primaries are too big, then the exhaust gas expands and slows down. This reduces the vacuum, and little to no air gets sucked in.
If the primaries are too small, then back pressure is created. This results in the piston having to work harder to push the exhaust gas out of the combustion chamber = loss of power.
Because exhaust travels at different speeds depending on engine RPM, exhaust systems are "tuned" for a specific RPM range.
At high RPMs the exhaust gas is traveling fast enough that it is possible to expand to large diameter primaries and still create travel fast enough have a scavenging effect.
At low RPMS the exhaust gas is traveling too slow to create a scavenging effect. So smaller primaries act as a venturi and increase the speed of the exhaust and create a scavenging effect.
This is why small exhaust primaries can show increased low end torque. However, those same primaries would not have the same power at a high RPM as would larger primaries tuned for high RPMs.
I will again admit that 84Turbo was right and that I was wrong.
I hope that we can all still get along and make sure CAC is
THE place to go for Corvette knowledge
