- Moderator
- #81
KANE
Moderator
- Joined
- Mar 2, 2002
- Messages
- 3,244
- Location
- KY
- Corvette
- Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
Because it can't create additional power. An internal combustion engine is an air pump. You make power by injesting (and eventually expelling) the maximum amount of air (and yes, fuel, but fuel is not the difficult part to increase in an engine). Backpressure reduces the mount of fresh air that can be pumped into an engine. It's simple physics, and it's common sense.
I don't think its about creating some "magical" additional power that the woman who throws monkey bones on the psychic friends network talks about.
I don't think the assertion has been about creating additional power- it's been about maximizing available potential.
And no one has stated that anyone needs intense amount of back pressure- but rather a small amount can help some engines overcome other problems. Perhaps you are confusing the scope of the subject. Besides- I don't think any of us will be able to escape a small amount of it since we don't live in academia.
No one is insisting that a large motor would make more power if it had unbelievably small primaries, a huge converter, and then three mufflers.
It's about using what is available and setting it up right for a particular purpose. And if a small amount of back pressure gets an engine where it needs to be for any number of reasons- then it has a purpose.
To be honest- it is really a non-issue. If things are set up to be the best they can in a given situation- then it is fine to have back some amount of back pressure. Unless the exhaust exits right at the head- just about everything will impede the escape of the exhaust gases.
In the case of some other components- such as turbos- they fetter the escape of the gas- but provide other benefits. I don't think the back pressure they create is a bad thing either because they create a different benefit that outweighs the back pressure they create- boost. So again- a blanket, polar statement like- all back pressure is bad, has no purpose, and should be avoided in all instances- isn't exactly true. If it were then all cars would have exhaust that exits it at the head and turbochargers wouldn't be used as folks went to extremes to avoid any back pressure whatsoever.
More importantly- the idea that a DOT & EPA legal, street driven car can achieve 0% back pressure, is unlikely to be had.
