petes74ttop
Vette79, I can't believe we are 20 posts into this. You have enough mechanical ability to do a top end rebuild, that's an 8 of 10 on the difficulty scale. Rear shocks are a 1, replacing the half shafts is a 2. Just loosen the french locks and remove the bolts. You may find it easier to remove the outboard bolts 1 at a time from the bottom and the inboard bolts 1 at a time from the top. Once all the bolts are removed pull out on the tail light end of the trailing arm. If there is not enough room to drop the outboard side of the half shaft then mark and rotate the camber bolt so you have enough room. Install the new half shaft, bolt it in, bend over the new french locks and re set the camber bolts.
Any shop can reset your camber.
The toe is adjusted at the front of the trailing arms and shops avoid that because there is too much labor because they don't have new shims and they don't have the proper bushing or the tools to install it.
Go for it, you'll be done in less that 1 hour and your new u joints will last another 20 years. PG.
Pete. AKA PG.
