Hard Clutch fixed
hdkeno
CT
2005 Victory Red coupe
Thanks to all the help from everyone on the forum reguarding my earlier post dealing with the hard clutch issue.
It is much better now.
What I did, to remedy this was put in a new return spring. (original one was not too good) and 2 new anti-rattle springs,lubed everything up,and pulled the cltuch fork boot and sprayed a little white lube in there on the fork bearing,but didnt go overboard.
I also was getting a annoying squeak in the cockpit,so i managed to hit the bushings on the pedal linkage also.
Took the 81 for a spin, and no more squeaks,and I can press the pedal down by hand.
I compared it tomy buddies 04 Tacoma 4 banger with hydraulic clutch and it is almost as soft as his.
later.Ken
bill81vette
Moderator
Troy,NY
1981 dark blue metallic
glad it was an easy fix!!!!!!!!! :upthumbs:upthumbs
