phrogs
Heres why im asking
when I bought the car bubba had removed the front bumper bracing and had unbolted the radiator frame and let it sit inside of the engine bay so the small block hood he installed on it would close..
so now my problem is the nose is sagging very baddly and the RH fender has a crack on it and it bows out at the wheel weel... problem is the crack was bubba repaired and its still there...so I started simple and I bolted the radiator frame back up and it is still sagging, Also the inner fender wells are both resting on the frame is that right?
and they both are bowing out in the top center towards the tires like there's been to much weight on the for many years? It doesn't look right at all...
Im thinking about replacing the wheel wells and removing that fender and fixing the damage and putting it back on the car..
I am going to remove the body sometime soon I just need to finish building my body dolly does that front frame support for the front bumper actually hold the nose up? and I am reaping the benefits of it being removed for so long?
In this picture look at the front fender and you can see where it is sagging at
ill get some better ones later..
johnny
johnny
