Topless
- Joined
- Nov 12, 2001
- Messages
- 444
- Location
- San Diego, CA
- Corvette
- 1992 Convt w/hard top; 2004 Z06 Z16; 1962 327/300
HI all...
Ok, my 92 vette is possesed. I was driving back from a road trip today, and every once and a while the engine would cut out momentarily. (usually when accompanied by a bump in the road) The Service Engine Soon light would flash too. Then in an instant, it would be back to normal.
Variations....
After I fueled up, when I strarted it, the Service ASR light and the Service Engine Soon lights came on. This was accompanied by high idle (1,500 rpm's) that would not drop. When I shut it off for a couple seconds and then restarted, it was normal (idle and lights).
I hit a bump once, and the cutting out happened as before, but this time the Service ASR light came on, and stayed on.
When I got closer to home, I hit a bump, and the engine went into a seizure. The RPM's were jumping from 0 to 2000 (where I had been running) and the car surged like crazy. I put in the clutch, and the car about died. I was able to get it to stop by tapping the brakes (hard) and that jerked the whole thing back together again.
I did blow a upper coolant hose a couple weeks ago, and that did get the front of the engine fairly wet. Other than that, I tagged the "x" brace/frame stffener on some road construction on the way out to Utah from Denver.
Oh, and other little electrical this have appeared about the same time.
1. I can not get the AC to change temps. I adjust the temp, but it still blows the same temp.
2. The AC fan will not change speed.
Someone please help me remove the electrical demons in my vette.
-Mike
Variations....
-Mike
