Help!!Smoke - steam coming into car!!
M
mikeyc4
Hi guys,got an alarming problem,whilst driving the car tonight,i noticed a faint burning smell,followed by smoke or steam coming out the air vent onto the window,it had that burning antifreeze smell i think!
Any ideas what it could be?is it safe to drive as it is?
jimmers
Canada
1990 Red Coupe 6 speed
If it smells like coolant and leaves a film on the window then its probably the heater core. Is the passenger side carpet wet?
M
mikeyc4
Yes it left condensation on the front windscreen,carpet is dry though,if its the core,is it hard -expensive job to do?or is there a way to bypass the core?
jimmers
Canada
You can bypass the heater core by connecting the 2 heater hoses together. I replaced my heater core last year. It wasnt hard to do, just very frustrating and time consuming. The heater core is only about $50, but if you took it to a garage the labour will kill you.
M
mikeyc4
So,do i need to remove the dash stil to get to the pipes?Or can it be done elsewhere?iS it easier to do than the core?
jimmers
Canada
The 2 heater hoses are under the hood and under the coolant reservoir. It is easier to bypass the heater core but then you wouldn't have any heat obviously.
M
mikeyc4
Ok,thanks for that,so i dont need to remove any part of the dash,just bypass it from under the bonnet?Just want to be sure!!
jimmers
Canada
I'm not sure what you mean by bonnet, but the 2 hoses are under the coolant reservoir.
muddywaters
wilkes-barre,pa.usa
1988 white 4+3 coupe 99 Torch Red 6spd. coupe
Hi, I did the by-pass on my 79 coupe , before I sold it I replaced the heater core, seats had to come out, dropped steering wheel, removed entire dash and ducting, if I were to keep the car, which would be strictly fair weather use, I would just by-pass the core , the dash stays cooler also. I only repaired it because everyone wants a heater that works..........
milehigreg
Denver Colorado
1989 Dark Red Coupe
"Bonnet" is Queen's English for hood. :) So yes Mikey, under the bonnet.
Can't imagine why anyone would want a working heater. ;shrug:)
M
mikeyc4
Yep,thats english for hood!!Got to get used to the "american" versions!!
So,is the bypass pipe something i need to make myself,or can you just buy one?If not,whats best to use to make one?
Thanks again!!
