high beams
jmbatt
South Meriden, CT
93 Comp. Yellow Coupe
When I pull back on the column stalk for high beams I get no "click" and no high beams either. Is it the switch or the actual headlights themselves? Thanks.
I asked the same question here and found the answer. Take the panel off under the steering wheel. Follow the rod all the way down from the high beam lever. Theres a switch mounted and is adjustable but it's very sensitive. The fasteners holding it are two and they are different sizes. That's what I can remember. Good Luck!
Now my signal lights don't work. Is this related to my high beam problem(see previous thresd) and if so what shall I check first? TIA.
