- Moderator
- #41
- Joined
- Feb 25, 2002
- Messages
- 4,315
- Location
- Cleveland, Ohio
- Corvette
- ZZ4, 700R4, Steeroids rack & pinion, VB&P Brakes
EASILY???Jack said:340HP at flywheel L82 quite possible with a good cam, headers & right tuneup. Evidence by: our "lift rule" circle track motors ... 355" 10:1 CR (flattops, NO vortec, only shaved plain jane 76cc production NONported heads), untouched eb 2101 intake, solid cam .480" valve lift EASILY make 370HP at flywheel on engine dyno w/ 110 gas ... with a TWO barrel carb ... ours & many others in the same ball park. Real engine dyno ... not that DD2K stuff.
(background info) The L82 had an additional 30hp over the base L48 in 1979. The bore and stroke were the same, so I don't know if the heads were different or intake manifold was different, or a combination of things.
What's the breakdown on getting 115 HP just from a cam & headers? Let's say that ya gain 20hp by just removing all the smog stuff. You're left to making an additional 95hp. Where does it come from? 50hp from headers, 45hp from cam? 35/60??? I'm not an engine builder, but from my past non-technical experience, those numbers sound generous.
