W
wolf_walker
It would have been easy if not for the stinking resistor wire in the points ignition. I could not locate a single other circuit that I felt like pulling power off of that would switch with the key and not go out when the starter engaged. I know it will suposidly work with the lower voltage, but I didnt perticularly want it that way, so I ended up droping the column and hunting around for the wire off the switch before it goes into the resistor. Why couldnt they just use an external resistor like Mopar?
Also shimmed the play out of the distributer, there was plenty, tach drive seems to still work, have to hunt up a new cable for it sometime.
In retrospect I probibly could have used the 12v off the starter in when it's engaged and also another on with the switch line, but I like the single wire method better overall. Just wish I hadent spent an hour or two hunting for first a correctly acting circuit, and then the resistor wire. Live and learn.
Works well, got the ignitor II and the matching coil, starts more readily, less of a bog when the secondaries are opened up. Still feels like the timing could use some re-curving, even though it's stock.
Good deal for the money, no more stinkin points..
Now, only 4,682 things lift to fix......
