40th Anniversary Instrument Cluster removal?
1993 40th Anniversary Corvette Topic
dhardy1062
New member
canton, tx
Anyone give a step by step instrument panel cluster removal. My LCD screen light up but cant read anything. Blank. I thought I knew how. I removed the battery cable, removed the outer trim surrounding the cluster. removed the four screws that hold the cluster in the dash. tilted the wheel down and removed the tilt column lever and there was still no way to remove the cluster. Can this be achieved lowering the steering column and if so what does that entail.? help
