- Thread starter
- #21
Jessica19699
so ecss my boyfriend checked the car out while I am at work today he said he disconnected the battery and tried a fuse without taking the headlight switch apart when he reconnected the battery the fuse blew, so he then disconnected the battery again and then took the headlight switch apart and popped off the orange wire connecter he replaced the blown fuse and reconnected the battery, he then said the fuse didn't blow he then disconnected the battery and reconnected the switch plug to the switch and reconnected the battery and he said the fuse didn't blow. he said the parking lights are working now, he also said there was a wire that wasn't connected to the plug of the headlight switch plug he took out he said it was bent back and maybe that might have hit something metal and caused it to short out, he think but isn't sure the wire that was out maybe goes to the aftermarket alarm but who knows..so why would it work now after all this is it possible there is a short in the headlight switch ? he is going to leave it apart until I come home today so I can look at it myself, you have any ideas why this might have happened? thanks
