dugr
I really appreciate this forum and the good information that is exchanged here.
I have a '94 coupe. Let me start at the beginning of what may, or may not, be the beginning of my problem: My PKE has not been responding to the "unlock" for a few days. So, I purchased and replaced the battery in the key fob (miles away from the car), today. Still, I had to unlock the door via the key to enter the car when I arrived home. I started the car and moved it a few feet, and the interior lights came on and stayed on the entire time I was driving, which was about 15 minutes. The lights stayed on when I exited the vehicle and the PKE secured the vehicle. I was away from the car for about 30 minutes. When I returned, the interior lights were off. Still the car did not unlock via the PKE, so I used the door key again. This time, the interior lights remained off. However, after about 10 minutes, the interior lights came on and remained again, for the reminder of about an 8 minute ride home. The lights remained on after the PKE secured the car.
I got to thinking that perhaps something about changing the battery in the key fob had something to do with all of this. So, I got out the owners manual. It said to do exactly what I did. However, I did go through the sequence of turning the PKE off and back on again and setting the doors to unlock.
All of this made no difference with what the interior lights were doing, but the doors are unlocking via the PKE now.
Again, I don't know if the problem I am having with the interior lights has anything to do with the PKE. It may be that it is just a coincidence that this problem came up when I changed the battery in the fob.
I was wondering if any of you have had this experience and if so, what was the fix?
I was beginning to suspect the light sensor on the dash. However, even if it was sending a "dark" signal, according to the owners manual, turning the ignition on should turn the interior lights off.
When I open the doors and push the door switch, there is a cycle sound, so I think the door switches are working.
The lights remain on somewhere between 15 and 20 minutes after the car is turned off and the PKE locks the doors. I don't know if the interior lights would go out while driving the vehicle this same amount of time. I have not tried that yet.
I appreciate any help you can give me.
Thanks!
dugr
Thanks!
dugr
