C
c4ever
Hey Nuke,
Good to hear from ya again. Good luck with your hunt for a mid year
warren s said:The L98 has a lot of torque, but struggles to breath at the top end. So is there a conventional way (besides replacing the motor) to solve this problem?
I have seen L98 cars run very strong with
1.6 rockers
long tube headers with low restriction mufflers
cleaned up heads(basic valve job, nothing serious)
polished plenum
aftermarket fuel regulator
modified air box / inlet
Low 13s
warren s said:Jedi86
Tough question. In real life, on an engine with some other mods such as a free flowing exhaust and intake, the right cam can give you up to 30hp. In a stock engine and exhaust you would see less, and at a differnt part of the power curve. So to directly answer your question i would say between 20 and 30 hp.
The cam would be about a five hour job (my guess) and most shops charge abouit 60 per hour for non-electrical work so that would be 300 bucks.
If you are going to do a cam, I would also get a new tining chain and gears, and obvisouly a gasket kit.
