B
bob1993
Has anyone else had a problem with replacement fuel filters leaking on an LT1? I changed the filter on my '93 yesterday. The old one was fine, no leaks, not clogged, just time for a new one. The replacement looks identical to the original. There aren't any o-rings or gaskets on either the new or old filter, and my service manual says there aren't supposed to be. The new filter went on fine, but when I turned the ignition on and fired up the fuel pump gas started streaming out of the connection to the outlet of the filter (the motor side). I figured I must have cross-threaded it or something, but it was on there fine. I pulled the new one off and put the old one back on and no leak. I even went back to the store and bought another brand of fuel filter with the same results. I've swapped it out half a dozen times now, the new ones always gush gas and the old one is fine. And I mean gushing, nothing that tape or sealer has any prayer of stopping. Anyone have any ideas or am I just going crazy? On the plus side I'm getting really good at swapping fuel filters.
