D
Donw
Not sure what I did wrong if anything? I have a 1969 Corvette original 4 speed. I was having problems (as many do) with it loacking in thrid putting it into reverse would only lock it against each other. I went ahead and replaced all linkage and accessories. Everything seemed to go ok. Pain in the butt getting all the clips on etc but was successful.
What is happening now is I still have it on Jacks, got in and have all four gears and seem pretty tight. Problem now is I can't get it into reverse? Got underneatch and it appears it is the arm on tranmission more then linkage.
Is there anything I have not done or need to do before it will go into reverse? I have not started car but like I say Ihave all four gears but no reverse.
I could sure use any help to figure out what is wrong? I appreciate any help I can get.
Thanks Much
DonW
Thanks Much
DonW
