I
ikom
Hi,
New member - new topic
I am in the process of deciding whether I should use a LS6 engine (used) or just build a small block chev for a project car. My parameters are as follows:
Max RPM 6000 (6200 preferred)
Horsepower at flywheel 450
my gear ratios are:
1st 3.82
2nd 2.048
3rd 1.407
4th 1.118
5th 0.928
6th 0.775
final drive 3,444
The specific question:
Is the LS6 capable of some easy (read cheap) mods to gain an extra 50 or so horsepower. (i.e. intake, cam or slight porting)?
Thanks.
BTW, I have not worked on chev small blocks for the past 15 or so years - so I will be on a very steep re-learning curve.
my gear ratios are:
1st 3.82
2nd 2.048
3rd 1.407
4th 1.118
5th 0.928
6th 0.775
final drive 3,444
Thanks.
