LT1 EFI
400hp_76
mobile,al,united states
Black 1976 STINGRAY cpe, T-tops
I found a site while doing a search for EFI solutions where the guy converts lt1 manifolds to fit SBC..My thinking is you can find LT1 parts for really cheap. Find a manifold, have it converted to fit your sbc. use the stock lt1 computer and control it with lt1 edit to customize the injection to your application. Help me figure out why this would not work.
http://www.lt1intake.com/files/pricelist.html
http://carputing.tripod.com/9697lt1edit.htm
Crimson Thunder
Orange Park FL USA
1970 Marboro Maroon Convertible
I would be weary of the routing of the coolant/thermostat lines since the LT1 is a dry intake manifold.I think i would spend the extra money and get the TPIS mini ram instead.
KANE
Moderator
KY
Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
The TGO guys have been doing this for years. The TPIS miniram is just an expensive alternative to doing it yourself.
http://www.thirdgen.org/techboard/alternative-port-efi-intakes/371751-post-pics-lt1-intake.html
If you are really trying to save the money- do the work yourself or have someone else do it for a reasonable price.
I have an LT1 intake and I may install it next summer myself. Right now, I'm happy w/ my TPI.
silver 80
madison,wi
1980 silver with blk interior 1987 blue / blue
Are you running the stock radiator? I'm looking for a lower hose that will fit my stock radiator and mate to the tpi water pump. Anyone have any sugestions?
tom
KANE
Moderator
KY
tom
I'm using the stock water pump and radiator. Just use the OEM stye hose if you are running the stock parts.
Where it gets tricky is finding the right hose from the TPI t-stat housing to the OEM radiator. My advice is to use toilet tissue rolls to make a mock up. Take that mock up to the local parts house and find a hose that most closely matches your cardboard mock up. You'll find a prefab hose that will match but you'll likely need to cut the ends off to get the usable portion you'll need.
I went with a 360* swivel housing. That allowed me to position the inlet wherever I wanted. Plus, it was chrome and matched my polished intake.
400hp_76
After doing a little more research i found the stealthram intake...If you dont want the hassle of converting the LT1 manifold you could go with the stealthram. It is a great piece and from articles ive read makes great power. Its a direct bolt on piece. I think that if you are handy enough and want to save money the lt1 is the route to take. The lt1 intakes are cheap and you can reuse stock fuel lines and regulator..Those two alone can save you a few hundred bucks.
