-=Topless=- [/i]
Graham-
From what I read from Redbob said:
I find this interesting.. Reason is the LT4 exhaust has an 'H' crossover right before the bends outward from the center to the mufflers.
Redbob here!
You're both right: The calculations that I did (back around '92), and the space available, dictated the crossover pipe location just where the LT4 cars, and the Export cars, have it.
Theory says that location should work, and my experience says it does work, although the reason it was done was not to reduce interior noise but to reduce Exterior ("passby") noise, so Export LT-5 cars could meet the European noise test requirements. (Even with the "noise test" power-reduction feature in the ZR-1 engine ECM, those cars couldn't meet the Euro noise law.)
Graham! Your idea of a "muffler plug" would also work quite well to reduce the noise!
We did that also early in our development program for the ZR-1.
BTW, when I say "our', I mean Calsonic, not GM!
Anyway, we took a variation on the early 2-outlet muffler, but redesigned internally to make both outlets functional. We got a huge reduction in muffler backpressure (big surprise, eh?) and a corresponding huge increase in noise, inside and out. Not pleasant at low RPM, but it really would sing at high RPM. Then we plugged one of the tips with a block of wood, with a screw through the side of the pipe to hold it in place, and another screw into the end of the plug so we could grab it to pull it out. With the plug in place, it sounded just exactly like stock.
That was so successful we got the actuators and controls from a Nissan Skyline (Japan-only twin-turbo car) "dual-mode" muffler (also produced by Calsonic), and we made a pair of butterfly valves, just like throttle butterflies, to go in the inboard pipes. We got the controller recalibrated to about a 3500 RPM start-to-open point.
That system was dang near perfect - low restriction at high-RPM, low-noise around town.
GM didn't want to spend the money, about $100 additional per car.
If I had a way of making an mpeg from a VHS tape, I could show you what the car looked/sounded like on our chassis dyno as it revved. Of course, that was a '90 model LT-5, not your LT-1.
Anyway - Graham: before you give those mufflers away, try a plug in one of the pipes on each muffler. You could whittle a piece of hardwood - belt-sander might be better, actually - and anchor it to the pipe with a very unobtrusive screw. I'd suggest the plug be at least 2" long; it doesn't need to be a perfect leak-tight fit In fact, if it is you'll be hard-pressed to ever pull it out. You could for that matter make a sheetmetal plate to cover the outer end of the plug, for better appearance. Although I think that just painting it flat black would work fine. You *might* find the inner end of the plug turning to charcoal over time... but another sheetmetal plate should solve that also.
But d*mn those mufflers look good on your car, Graham! Try the X-over, try the plugs - then if all else fails, sell 'em to me! I'll make 'em work!
Regards,
- R
