CFI-EFI
Gone but not forgotten
First, ignore the ramblings of the uninformed and irrational sometimes hijackers. Some people seem to have diarrhea of the mouth, keyboard or whatever applies here. One such poster to this thread will pop up where ever I go to aggravate, belittle, disrupt, and in general cause havoc most anywhere I post. He knows little to nothing, but seems determined to pollute the knowledge pool with senseless, often harmful trash. Go back and review posts 7 through 14 of this thread for a reminder.Very interesting replies. Have been away for a week. To try to answer your very well thought out reply. This motor was a brand new rebuild. All cleaned up and out, freshly painted up, new freeze plugs and new motor mounts. Steel crank, mild cam, bigger heads. new pistons. Ported intake (crossfire), Larger throttle bodies. It looks and runs like a nice rebuild.I dropped the pan and checked it out. I ran the coolant until warm then emptied it by removing the hoses and the radiator. Radiator leaked when I got the car home. You were right about the type of radiator. I've heard of the train of thought that says, running with out a thermostat doesn't offer enough restriction or hold back to let the coolant have enough time in the radiator to cool off. It seems to make sense. I take it you agree, my friend. This car runs cooler with out the stat? Would it make any sense to put in the stat housing, as a restricter, (no guts). Thus allowing more time for the coolant to cool off in the radiator. Or start out with a fresh 160 stat? Having only 1500 miles on the motor I've owned for about a year, I guess it should run cooler after a few thousand more miles. The engine came with a 160 degree stat. I bought a 195, I believe; and didn't put it in because it ran so warm on the 160. I did also put in synthetic oil with a quart of lucas, if that matters. Thank you CFI for taking the time to reply. I don't type very fast nor explain very well. I really am thank full for your thoughts. I do sound a bit frumpy. I wish I had your savy. Maybe in a year and a half, when I hope to retire, I can learn more about these cars that were ahead of their time as compared to the rest of the 84 auto line up of their day.Thanks, Larry
Now back to the subject at hand. Your new engine sounds like a great improvement. It should start to run cooler as it gets broken in. Usually synthetic oil is specifically NOT recommended in a new fresh rebuild. The reduced friction of synthetic oil can prolong or prohibit the seating of the piston rings.
As I stated above, a 160° thermostat is a poor idea in a car for normal use. No thermostat is a worse idea. Think about what a thermostat does. How it works and why they are used. They exist to facilitate engine warm up. They block the circulation of the coolant in the engine from passing through the radiator, until the engine is warmed up. No thermostat or a thermostat that opens too soon, delays that warm up. A thermostat doesn't regulate the max temp an engine can obtain. It only sets the minimum operating temp. When your engine is running too hot, a 160° stat, a 180° stat, and a 195° stat are ALL wide open. Your engine has to reach a certain minimum operating temperature, and maintain it long enough to purge the oil of normally occurring contaminants. Many of us don't drive our cars long enough to purge themselves under the best of conditions. Also, fuel economy and engine wear suffers at lower than optimum temps. Unless you have an engine that runs at the thermostat opening temp, changing to a cooler stat won't make the engine run one degree cooler. There is a fallacy to the coolant moving too fast with no stat theory, but because it is a bad idea in any case, there is no need to go into it. Good luck, and...
RACE ON!!!
