OK, maybe, but hotter than mine. My engine has never been apart so your thinner cylinder walls could be part if it. The new Delphi radiator is the stock configuration with a single row aluminum core with the plastic tanks? If so, that shouldn't be a problem. How long has it been in there? When you installed the radiator, did you do a good, thorough flush of the cooling system? Again, how long ago? When you say, "Before I took thermostat out, it ran..." are you saying that you are running the car without a thermostat? Bad news. That is worse than using a 160° thermostat. Why did you change from the stock stat? What was the reason? You DO know what a thermostat is, how it works, and it's purpose, right?
Unless your engine is brand fresh new, and the higher than necessary temps are the result of an engine still not broken in, I suspect an air flow problem. On the highway, with just the air flow of the car's speed, 50+ mph, my engine temp is just a couple of degrees above the thermostat temp. In 100°+ degrees ambient temps, maybe 10° to 15° higher. Below 60° ambient, the stat is barely open.
What temp fan switch are you using? On and off temps? We'll get that beast cooled down a bit without compromising good sense.
RACE ON!!!
