master cylinder Q for '85
sb66
New member
Ohio
1985 Corvette 2 tone blue coupe
well now that the fluid is clean and flushed - the problem persists
brake pedal holds, slowly goes down about an inch holds then another inch my foot applying constant heavy pressure
an abrupt stops can happen ok and a slow down stop as well - but the pedal does work it's way down
does that sound like master cylinder?
just curious - besides being a new and not rebuilt - does any one have any experience with dorman, cardone, centric or raybestos brake master cylinder? or even another brand that you trust?
bleeding the system does not seem to have helped the brake pedal hold.
any help would be greatly appreciated
thanks
Sean
Wagner or Raybestos. Never dealt with the others.
Its a hydraulic issue.
thanks
Sean
Hi Sean,
After fully rebuilding my brake system on my 84, and having issues with the bleeders in the rebuilt Cardone Calipers, I suspect either a dodgy bleeder (maybe crap in it) or the master cylinder.
The masters are meant to bled on the bench, but with some of the pressure bleeders, you should be able to get around this.
Check lines also for signs of leaking, this would indicate an air leak.
Tony
thanks
I ordered the raybestos and am going to attempt the bench bleed before installing
thnks
Sean
