4
4cefed
Aaron told me this morning the re-shaped lobe masters have been completed and delivered to the cam company doing my LT5 cams. The re-ground cam profile on the cam should be better than the one we were trying to use which was an old (30 years) profile design. This one is more specific to the ZR1 and should work well with the 415 cid motor Aaron is building for me.
The cam I wanted was the Lingenfelter 239 duration 445 lift cam. These cams seem to run really well with the big cubic inch LT5's. The ones I am going to get are 237 duration and 450 lift. Real close to what I wanted.
Thanks to Aaron who went out on a limb and has been busting his rear to get these done. Thanks Aaron, without you doing what you did we ZR1 nuts would have very limited cam shaft options. Thanks!
So in about a week or two we should know if they are going to work. Everybody keep your fingers crossed that this version will work. Larger cam shafts are really hard to come by and if this design works there will be modified LT5 cams available for years to come. This is good news to anyone who wants to do a bigger cubic inch motor. My search for the camshafts I wanted has taken roughly 21 months. I wanted something very similar to the Lingenfelter cam and it looks like we might be near the end of the road. "Oh please merciful God, please let these be the ones!!" I need a speed fix soon or I will need to go to the rubber room.
:crazy
:crazy
