silver00v6camaro
Active member
Okay here is what i have planed to do to fix what the moron built me for a street motor. The bottom end is bored over .30 so i have a 355. the builder used my l48 heads and a edelbrock cam that requires at least a 3000 stall. so I am going to go with this
350 chevy bored over 30
GM vortec heads
770 Holley Street avenger
Edelbrock Vortec performer intake
a lunati voodo cam specs:
Basic Operating RPM Range: 1,000-5,500 RPM
Intake Duration 050 inch Lift: 213
Exhaust Duration 050 inch Lift: 219
Duration at 050 inch Lift: 213 int./219 exh.
Advertised Intake Duration: 256
Advertised Exhaust Duration: 262
Advertised Duration: 256 int./262 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.454
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.468
Valve Lift with Factory Rocker Arm Ratio: 0.454 int./0.468 exh. lift
Lobe Separation (degrees): 112
I need to know what a good tq convert will be or will a factory one work.
What are you thoughts on this setup. good or bad. any advice is appriciated
thanks
GM vortec heads
thanks
