S
SwaveDave
I replaced my original starter with a Magnum Mini Starter. I am very certain i have it wired correctly as i noted the wires when i removed them. The problem i am having is, when i turn the key (or, hot start at the starter), i get one click and can see the starter shaft coming out and engaging the flywheel teeth nicely. But, it doesnt turn the flywheel - if i keep it energized for a few seconds, the big wire from the battery and big black ground wire to the chasis...gets hot. So does this sound like the Starter is trying to turn over the engine but cant ? (I do have higher than stock compr. ratio - it is now at 11-1). Any comments?
Thanks, Dave.
Thanks, Dave.
