K
keith hodge
:cry HI ALL-
I FINISHED MY FRAME OFF RESTO IN SEPTEMBER-I PAINTED THE CAR IN JULY
IN OCTOBER I NOTICED A SMALL BUBBLE OR BLISTER FORM IN REAR BELOW THE WINDOW--ALITTLE HISTORY-THE CAR WAS STRIPPED TO BARE GLASS 18YEARS AGO-CAR DIDNT NEED ANY BODY WORK-WAS ALL STRAIGHT AND WITH OUT DAMAGE--I SANDED THE PANELS AND APPLIED ECKLERS SPAY GEL COAT-BLOCKED IT OUT THEN A URATHANE SEALER/PRIMER-BLOCKED THAT OUT THEN SEALED AND PAINTED WITH DU PONT CHROMA PREMIER SYSTEM--BACK TO NOW---WHEN UNIT SAT IN 90 DEGREE WEATHER SOME SMALL BUBBLES APPEARED--TODAY AFTER ABOUT 9 APPEARED IN WARM TEMP I POCKED ONE WITH A NEEDLE -A LIGHT YELLOW LIQUID CAME OUT -IT DRIED LIKE TREE SAP-I CANT FOR THE LIFE OF ME FIGURE THIS ONE OUT --I SHOWED TO A FEW PEOPLE THAT HAVE BEEN IN THE PAINT BUSINESS LONGER THAN ME AND THEY HAVENT A CLUE-ONLY PRODUCT I HAVENT USED MUCH IS THE EKLERS SPAY GEL COAT --IS IT POSSIBLE SOMETHING HAPPENED?ANY IDEAS-CAR WAS PREPPED ALL CORRECTLY-AND THES ONLY APPEARED AFTER THE CAR WAS IN THE HEAT-PRIOR TO THAT NO BUBBLES--
I PUT A INFARED HEATER ON IT TODAY AND SOME MORE APPEARED-THEY COULD BE POPPED AND THE LIQUID WOULD COME OUT--IF THE LIQUID WAS LEFT ALONE IT WOULD CURE TO THE TREE SAP CONSISTANCY--IM NOT SURE WHAT TO DO--HAS ANYONE RUN ACROSS THIS?
KEITH
:eek :confused :cry
KEITH
![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
