New to me C7 Questions
boydn1
New member
Illinois
2015 C7
2015 3LT, tried to use the phone GPS plugged into the front two charging ports and it wouldn't charge with the phone GPS running. Maintained but would charge. Tried different plugs and cords, same thing. Any ideas?
I got the build sheet from GM and can't tell what some of them are. Like : 6X1 component FRT LH and many more. Is there a way to translate the codes into real english?
Thanks much!!
Norcross, Georgia, United Stat
2017 Arctic White Grand Sport
They are probably the older lower power plugs. I have a 17 and have no problem running GPS, playing music and charging using the plug in the center console. Never tried the ports behind the screen, which are the ports I think you are talking about.
boydn1
New member
Illinois
2015 C7
I only have one usb behind the screen. I’m talking about the one in front of the shifter and the one in the console
Those are the two that charge fine for me when using multiple components on my phone. I have other cars that have the same issue you have. The power standard for USB changed at some point. You probably have the older, reduced power ports.
