O Vette
I'm somewhat baffled but, it is not the first time I've got a 77 L-48 automatic. I was checking the oil and the dip stick tube fell out. Searched around the forums and web but, I still have a couple of questions. Any help is appreciated. I looked at the hole in the block and it seems to have some threads but, the dip stick tube doesn't. Tried to stick the tube back in, however it is to loose to stay in. The block end of the tube has a flare 1-3/4 inches from the end but, the tube only goes into the hole 3/4 of an inch so the flare doesn't get pressed into the tube. My questions are:
Was there ever a dip stick tube that screwed in?
Could this be the wrong tube for this '77?
Could I flare the end of the tube and jam it in?
Should I just order a new one from Zip or elsewhere?
I'd like to drive the car but am afraid oil will come out of the block hole, could I stick something in the hole as a very temporary fix to prevent oil from coming out?
Thanks!
Thanks!
