H
Henry
Has anyone solved this problem? There doesn't appear to be enough clearance to remove the oil pan without raising the motor. I have what sounds like a rod knock and I would like to check the lower end.
grumpyvette said:I have pulled the pan from several C-4 vettes without raiseing the motor off the motor mounts , be aware the crankshaft counterweights will prevent the pan from moveing back off the cross member unless the #1 piston is about 1/2 way down the cylinder so the counter weight is horizontally located thats the only major problem other than the two diagonal braces and the starter need to come off for clearance
