- Joined
- Aug 29, 2001
- Messages
- 3,239
- Location
- Norcross, Georgia, United Stat
- Corvette
- 2017 Arctic White Grand Sport
Started to pull the pan to take a look at the oil pump and shaft relating to some rapidly fluctuating oil pressure and a noise coming from the bottom back of the block.
I got the car up on jack stands. But that is as far as I got. How do you get the relay rod connections to come off. A puller? A pickle fork? There didn't seem to be much room between the pieces for a pickle fork so I tried a puller with no luck.
Part of the problem might be that it is a NAPA tool that says "Made in Taiwan" on the side of it. That puppy is going back tomorrow.
Any advice?
Any advice?
