- Moderator
- #61
- Joined
- Nov 9, 2000
- Messages
- 7,560
- Location
- Edgerton, Ohio, United States
- Corvette
- 1959 black 270hp (9/2/69), 1981 Beige L81(10/20/80)
Lookin' good Peter. The lighting is brilliant. (pun intended)
Tom
Tom
Jane Ann
It's probably no different than a C4, right?
Hello everybody,
This project will continue in 2007 so there will be some updates from time to time. If you're interested in this project and want to see pictures from day one please feel free to visit this topic in another forum. It's a dutch forum so all the text is in dutch but there are a lot more pictures there
Continuing with the center console, this is a quick mock up without the handbrake and auto-gearstick.
Also redone the crossmember to accept a true dual. It's not exactly as high as on the right side but it should do the trick.
From a friend I bought a right inner fender. Mine fender would take to much time to repair, this one only had a some problem so easy to fix. btw. I didn't do the polyester stuff but another friend who was kind enough to help me with this.After the repair I painted it and after that I put an extra paint-layer on the inside to match the other 3.
After that is was time to put the doors back in. The painter will get them out when painted. But this way we can still make some adjustments before the paint is on everything.
The new truflex rear bumper needed to be cut to accept the original parts. I wanted the original steel strips back on the bumper because I think they will distribute the tension more equally. After that we test fitted it on the vette. Same with the front bumper.
Next up the C4 fog lights. I wanted to change the orange cornering lights with the C4 fog lights. I already altered the cables to accept the fog lights. I've not added a extra button in the interior but linked it to the park lights and driving lights. The fog lights will go on with the park lights but when the driving lights will go on, they'll switch off. This way I don't have to ad an extra button and I can drive longer with the light assembly down![]()
I put to much paint stripper on the plastic of the lenses and when I found out it attacked the plastic it already melted some of the lens. Well, throwing it away was not my plan so I looked for a good hard clear plastic that doesn't turn yellow over time and made my own fog lights with clear lenses.
The next problem was the engine. After I changed the ignition I tried to start it but a no go.. Checked everything 3x but still no go. After I gave up the engine-builder came to help me out. The problem was not that hard.. I centered the distributor in the middle of the connection for spark plug #1. It should be in front so I was off about 10 degrees.. oeps..
I walked around and taped the vette when it was running without an exhaust system, very nice to hear but the sound and image is very crappy. You hear the engine almost die because there where setting the idle rpm. Enjoy!
http://members.home.nl/peter.verbogt/MVI_3670.AVI
The past few weeks I completed the undercarpet at the rear.
Putting the headlight assemblies back together. Almost everything is powder-coated, except for the shafts (polished them) and the springs (I tried to paint them black..) After that I fitted them into the vette. But as you can see this one still needs some adjustments.
And finally a picture of the vette with the headlights up and the fog lights in.
The vette will go to the painter in about 2 to 3 weeks I hope. After that I still have enough things to do if I want to graduate this year. And of course I need to polish some special things! A couple of months ago I got a package from Gerry (LP) who send my two sparkplugshields I didn't have. I still can't beleave somebody I haven't spoken to in person wants to send me some parts I need free of charge and without me asking for it! So I'm very glad with the shields and want to make them into very mirroring shiny shields! When I'm finished with them I'll post a picture here. So my special thanks goes out to Gerry!
Groeten Peter.
Also dop you have more in depth pictures and advice on rebuilding everything in the doors and repainting the insides of them. Also what is that for carpet underlayment? where did yopu get it.
I am going to start my interior restoration soon and need all the tips I can get. I thought about dynamat but its a convertible so to be more wind noise then road noise so I saw dynamat as a waste in my case.
Jane Ann
