- Thread starter
- #101
Peer81
Speed pro's with 4 valve reliefs (5cc). But if I would do it again I would go with max 2 valve reliefs for a better quench area.
Greetings Peter
Greetings Peter
Definitely the most elaborate work on an L81 to date, Peter!
I particularly like the bottom sections on the door panels, and the dash came out magnificent!
Peter, a bit off-topic, but would you have, or could you make a close-up picture of the seat switches on the drivers seat?
Ahh, that's where the problem is, I think: I figured that there is not enough room for the switch, but if you have cheat, and cut some foam away, yeah, that'll help.@Cor, there are two screws to connect the seat switch bezel to the seat, one in the front and one to the side (you can see it in picture). I'll take a close up picture this weekend if I have the time and don't forget. And while you're at it, cut some foam from the seat so there isn't any tension between the foam and the switch bezel.
Peter
