- Thread starter
- #121
Peer81
Cheat, cheat!??
I call it an upgrade! :gap
Greetings Peter
Greetings Peter
Peter, it is "oke"GerrySorry I forgot to answer your question. ....Rebuild the carb ones again with the proper epoxy, now need to redo the testing again, but that isn't a punishment really
Changed the u-joint bolts. I had 3 different types and I really like the socket head bolts to changed all of them into zink treated bolts.....And most important.. drive drive drive!
Greetings Peter
Sprayed two cans worth, Bud. All other areas are fine. Even placing my hand over the throttle horn does not help.Gerry,Could it possibly be the carb gasket
spay the base of the carb and see what happens
You probably already have, and I'm just show how senile I am getting
Bud
All I can remember is thinking, why do I buy al those gizmos and take everything apart for like 4 times and Gerry's runs just perfect the way it is! It's ashame she doesn't anymore.Is your dwell meter also indicating a lean condition? THen covering the choke valve with your hand should have the same effect as adding WD40. Like Bud says a vacuum leak would be the most common problem but tracing it can be a time consuming thing. Normally what I do is connect a vacuum meter to the vacuum line that goes to the air cleaner so you don't have to plug it. Then disconnect all the vacuum lines at the carb one by one and either plug them or put your finger on them to hear and see if there is any difference. Then the carb base is always a good one, I experienced the carb "settled" some more or I didn't tighten the bolts in the first place.... but I could give them some extra to almost one extra turn each. And off course an invisible leak would be the EGR valve not fully closing anymore. I made a metal plate that fits over the EGR hole on the intake to check this but it wasn't the problem in my case. You can look if the throttle body is cracked around the throttle valve openings (sides) and if the throttle valves fully when assembled (view from underside). Well that should be about it I think.Good luck with the hide and seak game.. :ughGreetings Peter
