hi all
IF, a big IF, all goes well this weekend hopefully I'll get the motor painted and without any major problems to fix from my efforts.
I'm now trying to plan ahead for the reassembly of everything and have just a few questions if you can put up with more of them from me.
I know from a recommendation from JohnZ that when I reinstall the intake manifold I should put a drop of Permatex on the tip of the intake holddown bolts to seal the threads and keep oil from seeping up. It was also recommended to me that when I put the oil filler tube back into the intake to put some anti-seize on the bottom of it before I put it in.
what about all the rest of the bolts of parts I took off the motor and other fittings?
How do I know when it's appropiate to use a thread sealer such as the Permatex, or an anti-sieze, or locktite, or whatever?
I have to reinstall the following and not sure what I should use on any of the bolts or fittings if I should use anything at all:
water pump
exhaust manifolds
sidepeipes to exhaust manifolds
radiator hoses to intake and waterpump
all the heater hoses
bypass fitting and hose from WP to intake
new intake nipple fittings (for water pump and heater hoses)
intake manifold
oil filler tube on intake
valve covers
any of the other parts that are off I don't foresee issues that I have questions about............ yet.
also, someone else also recommended that I use "Indian Head" to smear around the insides of the various hoses - radiator hoses and heater hoses- when I go to put them all back on. I've never seen that mentioned in threads on here. Is that a good idea?
sorry for all the 'newbie" type questions again, but i want to make sure I put things back together correctly and to reduce my chances of leaks when i'm done.
water pump
exhaust manifolds
intake manifold
valve covers
