mvftw
Right, Cats started everywhere in '75, but smog motors started earlier, including low compression stated in '71. '70 was the Last real muscle year!
mvftw said:Half true...'74 had duals and smog. Smog started everywhere in '71 and just got worse...![]()
JLMvette73 said:Anyone tried out one of the mufflerless chambered systems that are available?
78SilvAnniv said:I purchased a used set of ss MidAmerica chambered from a CAC member last fall.
Freezing cold outside after the installation but I drove around with the windows down and a HUGE grin on my face!
Now my GM crate engine sounds like a BB when it idles! When I step on the go pedal, she ROARS!
Husband and I can still have a conversation while driving, but you can definitely hear the exhaust rumble. Any acceleration makes me smile. My mpg has suffered because I like to listen to it accelerate.
As for the exhaust smell...sometimes that can be a fuel smell from the evaporative canister not working correctly, but if it is an exhaust smell...that can occur with a new exhaust system.
My chambered did not have that smell because it was used when I purchased it and had already worked its way through that.
Perhaps there is an exhaust leak?
Running rich?
Timing issue?
Heidi
I have true dual exhaust now with cats.
Blue82 said:If you go dual you should move it up to the header and probably should install one in each header so you can monitor both sides of the motor. I have seen mods for this so you'll have to look around.
Blue82 said:Also, if you stay with the current setup, you might want to mod the sensor to a heated O2. it works much better that way because it is located so far back from the flame path that it has a hard time keeping the proper temp.
