- Joined
- Aug 30, 2002
- Messages
- 1,533
- Location
- Colorado Springs, CO USA
- Corvette
- 84 Z51 auto R.I.P. 89 black roadster SOLD
ran long enough to drop idle, stiil way high, hey im from ny just moved to
virginia, guess i have to do the plenum gasket. see if you have a vacuum line coming from the front of the egr solenoid. service manual doesnt show one but theres a clip for one otherwise i just have two going to the solenoid, just wanna make sure--------------- john
The idle screws are the only thing that will control the idle speed.bill,
just thought to say hello, and thanks for all the info. where i stand now
set the timing you were right timing was set with that plug connected
now im set at 6 btdc. runs better but not 100%, parts replaced idle control
valves, 02 sensor, map sensor, knock sensor, fuel filter, coil, wires, cap,
rotor. only problem left is very high idle in park, oh, also checked vacuum
hoses. thought of drilling out those idle stops. but looks like if i back
those down, it still wont bring idle down enough. any thoughts
thank you--------------john
Heh, heh. We haven't disagreed on anything before, Bill. So this is a first!I disagree...a vacuum leak can most definitely cause an increase in idle speed! The IAC valves also control idle speed.
Bill
OK, so let me ask you this. What adjustment would you change to purposely increase of decrease the idle speed?The idle speed stop, right?
Woops, gotta go, Lightning hits real close.....
Yep. you're right, the IAC's and the ECM will modify the idle speed, assuming all the settings on the timing, TB's and TPS are set right. But the idle screws will need to be accessable in order to balance the TB's and set the TPS initially.Hey nuthin wrong with a little respectful disagreement! heheh
I think the distinction we need to make here is a properly running engine vs. one with some sort of mechanical problem. I guess the point I'm making is that if my engine suddenly started idling at 1500RPM I would NOT immediately go to adjust the idle screw to bring it down!
Now, barring any vacuum leaks, or malfunctioning IAC valves, or anything like that...if I wanted to change my idle I'd go to the adjustment screw!
Also keep in mind that the EPROM has an idle setting in it...if the adjustment screw is set below that point then the ECM will keep the idle at the programmed setting via the IAC valves. Hence, the idle stop screw should ONLY be adjusted with the IAC valves CLOSED! The IAC valves should only be affecting idle when in gear (for automatics), and when the AC is on.
Bottom line...the idle stop screw is NOT totally independant, there ARE other things that can effect idle speed.
Stay away from that lightning bro!
Bill
