hmcquade
Does anyone have any idea what Plug the person is writing about in this post:
To Jon Height: When you have erratic shifting in the overdrive take a look at the OD indicator light. If the light is going on and off with the OD unit then it is a computer/ecm related problem. If the light stays on but it kicks in and out ( called hunting ) it usually means that the OD unit is slipping.
On that plug. You must only remove them with an 8 point 9/16 socket. If you have stripped it, drop your pan and push out the electrical connector, right next to the plug. Fill the unit thru the connector hole and snap it back in.
Thanks,
Hugh
Thanks,
Hugh
