disconnect both battery terminals, drain all oil and coolent, use quality jack stands and wheel chocks, put the parking break on, keep a fire extinguisher handy , make very sure the car cant be knocked off the jack stands,THINK THU EVERY MOVE,DON,T ALLOW YOUR HANDS INTO PLACES THAT WILL GET CRUSHED IF SOMETHING SLIPS OR BREAKS,
DON,T FORGET TO BRING DOZENS OF THOSE TIE ON LINEN TAGS TO LABEL EVERY CONNECTOR AS YOU REMOVE IT AS TO WHERE IT CONNECTS, a marker that gas and oil won,t make the ink run, AND A DIGITAL CAMERA TO
TAKE DOZENS OF PICTURES AS YOU DO THE WIRE REMOVAL TO USE LATER AS A REFERANCE TO MAKE THE RE-INSTALL EASIER
BTW theres no way to write all the necessary info on the tag so just write a large number and then write all your info on a large pad with that number on the top of the page and the same number on the back of any photo if you can later when the pictures are developed or down loaded to your computer and printed out
remember to support the transmission, BEFORE you pull the engine , just letting it drop could cost you big$$$
keep a 5 gallon bucket around to theow ALL the bolts in but take the time to lable zip lock bags for each group of bolts also ,(bags like )(intake bolts)(header bolts)(accesories)(water pump)(motor mount)(bellhouseing) (head bolts)CAN HELP A GREAT DEAL IN GETTING THE CORRECT BOLTS BACK IN THE CORRECT SPOTS
clean all bolts befor reuse with a mix of diesel/carb cleaner and a wire brush and look for worn or corroaded parts needing replavement
YOU DON,T NEED to pull the hood to pull the engine,(MOST CARS) but if you do,lightly dust the hood mount locations with white paint,this allows you to exactly replace the hood alighnment correctly by showing exactly how they were previously installed (RECOVER(REPAINT) AFTER THE HOODS REPLACED WITH BLACK paint AGAIN)
take lots of notes and pictures, lable every connection
its far easier with two people!
adding an engine leveler and swivel to your engine crane makes things far easier
adding a swivel like this between the leveler and crane GREATLY AIDS THE ENGINES REMOVAL, DON,T GET STUPID or CHEAP, GET THE 3400lb rated one not the 1200lb size (REMEMBER YOULL BE UNDER THAT ENGINE SOMETIMES)
youll need two of these rated at similar load strength[/b]
