Question: PVC Valve Location '93
DogAlpha
Altoona, PA
1993 Polo Green Coupe
PVC Valve Location '93? Can't find it and I don't own a shop manual. Looked on valve covers(logical?) but not there?:duh
DogAlpha,
The PCV is on the intake manifold (drivers side). You will need to remove the black plastic fuel rail cover to access it.
B17Crew
:w
Right side vavle cover. remove fuel rail cover. it is on the injector side of the valve cover;)
Sounds like GM changed sides from the ’93-’96 as the PVC on the ’96 is on the drivers side. Just goes to show the devils in the details, thanks for clearing up my error!
B17Crew
:w
B17Crew
:w
Must have been changed in 94 because my PCV valve is on the drivers side. Mine is an early production 94 (built Sept 03).
Thanks, toms94!
I had a ’93 but can’t remember if it was located on drivers or passengers side back then.
B17Crew
:w
