S
snitcher
On my 84vette ...what makes the "clank" noise in the rear end when I put it in gear? How how can I fix this?
You were in luck. I just had the left rear bearing replaced on my '85 and it was $517.00. The part alone was $211.00. I have bought 3 of them now between my '85 and my '86 and all of them cost roughly that amount at the parts store where I get a mechanic's discount.vince v said:A few months ago, I ran over a pot hole. I instanly got a clunking noise. Pulled into a gas station, the right rear tire had a wobble in it. The mechanic tightened it and got me home. A few day later it started again. A local mechanic checked it out and said that it needed a right hub and bearing. Had it replaced, the clunk is gone. Expect to pay between $110 and $300, that's for the hub/bearing, then the labor.
Good luck
I bought my hub from http://www.tld-corvette.com/, for $115. The shop charged 4 hours (75/hr.), $300. Total was $415. I wanted to do the work my self, really didn't want to do it in the driveway.boblx2a said:You were in luck. I just had the left rear bearing replaced on my '85 and it was $517.00. The part alone was $211.00. I have bought 3 of them now between my '85 and my '86 and all of them cost roughly that amount at the parts store where I get a mechanic's discount.
I replaced the others myself but got tired of fighting with those parking brakes so I decided to spell myself this time. Maybe a $300.00 labor charge will cure me of that sickness!
The garage said that the book called for 6 hours and he did it in just 4. Sure glad it didn't take him 6!
do ya mind telling me what that cost? i hear a clunk sometimes when i back out of my sloped driveway.Wayne88 said:I just had my 4 half shaft U-Joints replaced.
There was a big clunk before, now its mostly gone.
I would recommand that you post a new thread, to get a fresh set of eyes. Good luck.krgoodman said:do ya mind telling me what that cost? i hear a clunk sometimes when i back out of my sloped driveway.
thanks, email always welcomed
kevin
Guess what?vettered91 said:I've been tracking down that clank for more than a year, took off the transmission (to change oil pump & TC), replaced 4 of the 6 "U" joints, changed ring, pinion & bearings!
The "clunk" keeps "growing stronger", there's only two more "U" joints to go, and after that: ¿what else can I do?![]()
I hope these thread can give us a light! (just in case my two last "U" joints are not the answer)
Sounds good.vettered91 said:Guess what?
I had a "klunk" and some kind of "klink". It always seemed to come from the left half shaft. When we lifted de car to change the last two "U" joints, we noticed that we could move the left tire a little (ok,maybe more than a "little") so in a close look you could see that the left rear tie rod end was worn-out and making noice!
We checked the other side and it was in a better shape but still with some "play". Ended up changing both sides and now I can feel the difference in a more quiet and better handling (my left tire was "turning left" at every launch)
Now the "klink" its gone, but I still hear some "klunk" from time to time!!! :confused
Take care!![]()
