eoseitz
Well I finally replaced my u joints on the front shaft and the drivers side half shaft. The front shaft went fine. The driver side half shaft was hell though. The side side that connects to the wheel gave me tons of problems. It was stuck in there and wouldn't come out. I ended up bending the bracket that connects the u joint to the wheel. I got it bent back into shape by drilling holes in an old rotor and and bolting the bracket to it. I then heated it and tighted the bolts until it was straight again. The u joints stuck on the knuckle side that attaches to the pumpkin as well. I heated it a lot before attempting to break that one loose. It came right out. I'd highly recommend heat and WD before attempting to break them loose. Just thought I'd share this info and vent a little bit. It can easily turn into a 12 hour job if you bend things. ad
