REAR SWAY BAR
  • Thread starter Thread starter fxsts
F
fxsts
Maybe some can answer a question. Were all c3's built with rear sway bars. I went to a corvette show today and a 75, a 73 were without, but a 78 had one. The reason I ask is. my 74 came without one.
Help?
Thanks in advance
sway Bar
Can't answer that question, but big blocks in the early 70's came with a rear sway bar. My 71LT1 had none, but it was easy to add one. Muddywaters
I believe the FE7 option (Gymkhana Suspension) Sharks came with the rear bar and a little bigger front one ;) There are other subtle difference's too with the FE7 cars ;)
Bud
I have always heard the big blocks came with them. I have an '81 with gymkana suspension that does not have it, so all I am doing here is adding to the confusion. God bless, Sensei
My 77 L-48 had one but it was only about 3/8" diameter. Not hardly worth having. Now I have a 7/8" one.
My 74 BB came with the above as well... and I also switched to VBP 7/8" with Poly bushings.
If you have the opportunity, upgrade front and back... what a difference!!!
With a small block do not use any sway bar unless you have at least a 1 1/8 front. It WILL cause oversteer at highway speed that is dangerous. Trust me.
Lotsa research and info on this out there.
Thanks for the info
I really appreciate all the input.
Terry
Mine has a 1 1/8" front and a 7/8" rear sway bars.
I don't think I have a rear sway bar. In fact, I'm almost 100% positive that I don't. I do have a front one though...
