B
bigvette1
Oil Smoking
I am reading this post and damn if it is not a direct quote of the problems I have on a BB after a rebuilt. Difference is, the heads were redone with new everything including cut for and installed PC seals. Supposed to be great.
The smoking is predominant after totally warm - metal expands. One garage said since the bottom end was bored etc they would think the cylinder walls are not a perfect bore top to bottom and when warm, oil sucks up the walls. I have tried 3 differnet intakes and 3 different carbs with no affect. My PCV lines are not wet with oil and the valve covers have baffles in them.
I with stupid luck may have stumbled onto something this week. The timing was real hard to set and the engine bucked when warm and then fired. I pulled the distributor, found tdc and put it back in like the book shows on a BB - rotor pointing to #1 tower but having #1 aligned near the vacuum can, which was 1 tower clockwise. This also with a MSD distributor put the mag pickup dead center in the pickup coil. Changed the wires around and presto the timing was easy to set and did not show signs of being super advanced. Talked to an "expert" and he said you most likely had a problem of pulling fuel from the boosters and actually pulling oil from the cylinder walls because of the super advanced timing - called it a reversion process. Anyway after an hour of running the amount of smoking was reduced to almost nothing. I probably have a ton of oil and gas on the valves, in the pipes and in the mufflers. Just maybe......
Sorry it was so long, just sharing an experience that might be something to look for. Still think the bore job was suspect.
Do you still have your PCV system still hooked up along with the passenger side breather tube? If so, pull the PCV off and check that rubber tube that goes from the PCV to the carb. Let us know if it is soaked in oil inside the tube. When I did my rebuild I had oil blowing past the PCV and into the intake manifold via this rubber tube. I installed an oil catch can to resolve the issue of oil being sucked in to the intake and mixing with the air fuel mixture for burn.
