chevyaddict
Ok... this head gasket project on my 90 is a PAIN IN THE BUTT. Mainly because I keep running into bolts that just don't want to come undone. The driver's side head gasket blew so I'm replacing it. Seeing as this is probably more than I should have bitten off, I'm contemplating replacing only the driver's side and not both because the ac compressor removal and emission crap on the pass side is going to be a nightmare. Also having a bad back due to a post-surgery reherniated disc is not helping matters much. So what would you do?
Replace only the leaky gasket?
Replace them both while the car is 80% apart?
I've already decided I'm going to replace the water pump while I have everything apart. One less thing to have to deal with later....
